Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
electrovoz
Страница 102, пост 2022.
Проверял термостабильность SMD конденсаторов NP0. При нагревании паяльником до плавления припоя емкость изменялась от 5,36 до 5,37 нФ.
RUN1
Цитата(electrovoz @ 1.6.2009, 11:29) *
Резистор как в обновленной схеме вместо 1 МОм - 100 кОм, конденсатор вместо 2,2 мкФ - 100 мкФ. В СВкаде нет именно этих полевиков, потому и изменения.
Ок спасибо!
strannicmd
electrovoz,Может Сообщение #2022 ?
RUN1
Оно самое
supryur
Вот такой вопросик - на какое минимальное расстояние стоить отнести дросель от силового транса ? ток аппарата до 160А , а то получается в корпусе почти рядом друг с другом , обмотки дроселя на растоянии в 1 см от магнитопровода тарнса....
Гость_Pavel_*
Пробую калькулятор лысого! Намотал пробного провода 15 витков, сопротивление есть только 1,8 ома 10 Вт, на осцилографе смотрю пирамидки, напряжение плавно поднимаю автотрансформатором, дошел до 50 В насыщения нет, ток плавно растет при 50 вольтах он был 1.5 А, автотрансформатор тоже жжужать сильнее начинает.
1. Вопрос нужно обязательно апряжение довести до 310В ?
2. При введении зазора ток намагничивания будет расти?
3. Сильно начинает греться диод который замыкает конец первички трансформатора на + 300В, так и должно или нет ? остальное чуть теплое.
4. Разоменутую схему - без трансформатора включать можно?
Лопух
1. Нужно смотреть насыщение на полном напряжении сети
2. Обязательно (если только транс не насыщается.В последнем случае наоборот упадет) . Но при прочих равных условиях можно намотать меньше витков.
3. Нет
4. Ваще не понял
gorbun75
Желательно поднять ЛАТРОМ до 250 вольт , сети бывают разные . Еще при этом желательно нагреть транс - ор феном градусов до 100 .
А транс-ор размагничивается ? Возможно это связано с нагревом диода .
Гость_Pavel_*
Да трансформатор размагничивается на почему то ток растет, я думал он должен дойти до определенного значения и встать, а он растет и Латр жжужать начинает не по детски.
кабельщик
Гость Павел, напряжение нужно доводить, как сказал gorbun75, до 250 переменки, т.е. до 350 постоянки на банках. Это будет нормальной проверкой...
Andrey_G
Народ, кому интерестно - управа с регулировкой по среднему на uc-ке (а-ля Telwin) + antistick (на ОР1.2) от 6 ноги.
Проверено на макете, результат более чем удовлетворительный... фото макета в нагрузку:
Гость_Pavel_*
А лампочку повесить до выпремителя можно ? или не нужно?
Лопух
Если вешать лампочку, то между конденсаторами сетевого фильтра и мостом. Если повесить до выпрямителя, толку не будет
RUN1
Andrey_G итересно конешно от чего-же не интнресно то!
между +300 и ключами вешаешь лампочку и в перед способ примитивный но вполне нормально можно определится с витками
Andrey_G
Лампочку вообще бесполезно туда пихать, напруга то на ней падает. я вешаю лампочу только при первом включении, до выпрямителя, на случай багов в монтаже.
Лопух
О том и речь. На время отладки и проверки весьма желательно.
А скажите, у вас в макете оптодрайверы? Если да, то от чего питаете: от дежурки или отдельного преобразователя?
Andrey_G
Да, оптика, 3120. питаю от дежурки. В начале хотел отдельный преобразователь для этого дела, да решил, что в этом случае проще ТГР использовать чем оптику...
вот полная схема:
Valter
Цитата(Andrey_G @ 1.6.2009, 12:43) *
вот полная схема:
А зачем эта приблуда ВС327 после оптики?
Гость_Pavel_*
Чего то я уже запарился! Есть 6 строчников с проницаемостью 3000 хотел проверить калькулятором проверить сколько витков нужно мотать так и не разобрался ЛАТР греется 500Вт и из него запахло жеренным! Так же есть 4 комплекта 20*28 проницаемость не написана!
1. Какой ток может бежать максимальный при проверке калькулятором? (диод 30 А греется здорово).
Подключил лампочку 100Вт последовательно трансформатору - без проблем дошел до 150 В дальше какой то ограничитель вкручен завтра его уберу.
Без лампочки 50В и 3А ток все начинает греться кроме феррита он холодный!
Подскажите сколько мотать лучше чтоб нормально работало?
Д713
на 6 строчниках при 33-35кГц 16/5 витков,можно "лысым" даже не проверять.
1-2 А.
Andrey_G
На всяк, воткнул чтоб попробовать. Если ключи будут нормально переключаться и с одним лишь резюком в 8-10 ом в затворах, то выкину (на мой взгляд проше выкинуть, чем лепить навеснухой потом если понадобится icon_smile.gif ). вообще там планировалось отрицательное смещение под PD1, но поставил HGTG, потому осталось так.
Quest
Andrey_G, hcpl 3120 легко тянет 2 SPW47N60 с емкостью затвора 7500пф каждый через резисторы 4,7 ом. Pd1 обратное смещение не нужно. Может потребоваться если делать 3 фазник, где напряжение питания будет высокое, но конечно с другим ключом.
Andrey_G
Цитата(Quest @ 1.6.2009, 20:10) *
Andrey_G, hcpl 3120 легко тянет 2 SPW47N60 с емкостью затвора 7500пф каждый через резисторы 4,7 ом. Pd1 обратное смещение не нужно....
У hcpl пиковый ток в 2А по шииту, как она может 6А тянуть (при 15В на затворе)... А обратное смещение для борьбы с хвостом PD1, не нужно с сильно могучими снабберами, но у меня по конструктиву сильномогучие не лезут, да и работать они будут на 100кГц.
Д713
А обратное смещение для борьбы с хвостом PD1..
можно поподробнее?
есть подозрение,что "хвост" PD1 нужно принимать таким какой он есть.
САНЕК
А как на счёт заряженых банок?Их заряда хватит что бы рвануть ваши ключики.
Quest
Andrey_G, пиковый ток длится 4,7х7500пф=35нс. Такой крутой фронт размажется в проводниках и до кристалла весь не дойдет. Хотя на 100кГц будет в 2 раза тяжелее чем на 50.
pik
Цитата(Wiew @ 31.5.2009, 19:07) *
вы наверное 3844 используете, у нее это как раз порог запуска (или перемаркерованная может)
Спасибо за внимание. на мелкосхеме написано UC3845N , на обратной стороне - INDIA. можно ли как то еще удостовериться в истине?
Andrey_G
Цитата(Д713 @ 1.6.2009, 20:28) *
можно поподробнее?
а, пардон, не совсем некорректно выразился... сам хвост ни куда не денется, база биполярника недоступна, но можно "выключить" внутренний полевик быстрее, чтоб раньше началось рассасывание зарядов в биполярнике, тем самым несколько уменьшить общее время выключения и снизить дин. потери. Где это прочитал не помню, там даже график был при -5, -10, -15 смещении... попробую, когда PD1 приедут....
Quest, с оптикой первый опыт, потому не стал рисковать... в тех схемах, что нашел с 3120, везде или буфер или отрицательное смещение с "большим" (8-15ом) Rg.
Коля
Под вечер был часок свободный и я решил проверить: действительно ли хороший кондёр у меня на 4 ноге. Его ёмкость должна быть 4700 пикофарад. Как утверждал продавец, у них самый лучший ТКЕ из его кондёров такой ёмкости, и продавал он их по 20 Руб. Ну вообщем подцепил к LC меру, фактическая ёмкость при комнатной температуре 4,34 нан, подул на него- 4,25 нан, прогрел паяльным феном при 100 гр 4,75 нан, прогрел феном 200 гр. 4,85 нан. Одним словом полная Ж..па. Кстати, всю силу я гонял на частоте 39,84 кГц, я же совсем забыл, что когда осцилл настраивал, то не понимал что крутил. И в итоге разобрался. Так вот амплитуду я отрегулировал по калибратору, а про длительность забыл. Вот и неправильно всё я считал, в том числе и К.зап. Удачи всем.
САНЕК
Можно смело на помойку,или в другой девайс.У неё невозможно ограничить Кзап.
pik
Раньше никогда не сталкивался с перемаркировкой. как же тогда отличать от настоящей?
Д713
..как же тогда отличать от настоящей?
подцепить к регулируемому 5-20в БП и посмотреть пороги вкл-выкл.
часто и густо LM78xx оказываются LM78Lxx,со 100мА уходят в защиту.
бывает и LM317,LM337 не держат заявленный ток.
grek
САНЕК, можно пояснить, почему невозможно ограничить Кзап?
Гость_гость_*
В каком месте тут Ж...па ? Вы видимо хотели чтоб у вас и при 300 градусах ёмкость не поплыла. Вы возьмите жёлтого китайчика у которого ёмкость меняется от температуры тела, вот это Ж...па как вы выражаетесь. В конце концов найдите шит на тот кондер что купили или на худой конец у форумцев спросите об этом кондёре, а выводы не стоит вам делать дабы потом не стыдиться самого себя.
pik
пойду попытаю, похоже придется снова на базар
Д713
да во всех местах,начиная с колиных 100*С на глаз..
Коля
дык ёмкость на 5% максимум должна меняться, а здесь меняется на 12% ИМХО это ( )О( ). А жёлтые кондёры я завтра посмотрю.
Гость_гость_*
5% это отклонение от номинальной емкости, а не при нагреве до 200 градусов, хотя ваше (ИМХО) действительно хрен оспоришь.
Camelot
если вы так сильно переживаете по поводу частоты при отрицательной температуре, посмотрите в каком температурном диапазоне работает наша любимая 3845... хотите при минусах стабильной работы берите 1845 ил 2845, а кондёры в частотозадающих цепях ставлю по советам форумчан китайские бордовые плёночники из мониторов и никаких проблем, кстати если при минусе инвертором варить его надо полностью в лаке утопить иначе конденсат сделает своё грязное дело.
Д713
..кстати если при минусе инвертором варить его надо полностью в лаке утопить иначе конденсат сделает своё грязное дело.
там не столько "минус",как комбинация минус-плюс.
а в лаке топим,и не только по температурным соображениям.
Camelot
это и имел ввиду, просто не стал вдаваться в подробности.
кто нить вообще сувал управу на 3845 в морозильник? это не праздный интерес, просто лень самому сей научный экскремент производить, а сварочник на продажу, не хотелось бы чтобы после первых заморозков его принесли на ремонт...
gorbun75
Сомнительно , что такую копеечную микросхему будут перемаркировывать .
pik
Скорее другой девайс. Посмотрел в Сов.справочнике - разница 3844 и 3845 только по питанию, все остальное одинаково. проверил свою- включение 14,4 выключение 9,2 вольт. Если применять, надо питание поднимать до 15вольт, а это многовато для релюхи и кулеров. Или я не прав?
Д713
на релюху транзюк с хорошим падением,а куллерам по барабану,даже обдув поприличнее будет.
pik
Наши продавцы берут что подешевле и возврат им сделать трудно. А если умножить 40рэ на энное количество, то денег будет много icon_biggrin.gif
gorbun75
И ТГР-ру это может не понравиться .Лучше найдите нормальную микросхему .Чем меньше отклоняешься от схемы Бармалея тем быстрее получится сварочник . Я сам несколько раз отклонялся и почти всегда выходило , что быстрее и дешевле вернуться . Везде понатыканы подводные камни .
pik
Наверно можно резик поставить послед с реле чтобы транзистор не трогать? Еще один вопрос - У меня есть по одному комплекту Е65 и Е70. Какой лучше применить в сварочнике до 140А. Чисто для троечки? С уважением.
omeech
Ага смотрел в Платане Е65 комплектом продаются, а наши их половинками толкают. Спросил с них, а они глаза круглые "как хотим так и прдаем"..
HEMELL
Всем добрый вечер. Хочу спросить:
Кто собирал Кольт 1300, какой на сегодня самый модный ТГР для этого апарата, или может быть есть несколько вариантов? Если несколько то желательно под К20*16*6. Частота планируеться - 50кГц. Интересует процес изготовления транса (колцо ломать - не ломать) ну и кол-во витков. Спасибо.
pik
Цитата(gorbun75 @ 1.6.2009, 18:25) *
Чем меньше отклоняешься от схемы Бармалея тем быстрее ролучиться сварочник .
Интересно получается - схеме несколько лет, а изменений почти нет. Это тянет на гениальность! (уверяю это не ирония! )
