Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
oleg1ma
Цитата(mono @ 5.4.2012, 10:13) *
Спасибо за инфу, почитаю, а схема в последнем архиве полностью соответствует печатке?
200 А меня не интересует, сеть не выдержит, максимум снимал 160А и 32В, но через 30 сек автомат в квартире вырубает и розетку пришлось поменять. Просто понадобился ещё один сварочник, думаю за 4 года может есть улучшения, а чем пилить кольцо?, и зазор потом как фиксировать? Можно ли вместо такого кольца феррит ставить на 2000? Сомневаюсь, что найду у себя нужное колечко. Вторичку мотаете шиной или лутцем? И какая получается Ls на кольце?
Заполните в профиле, где проживаете, что-бы знать что советовать.На последнем колечке Р4 инд.получилась 8300 мкГн и работает нормально.
mono
Я имел ввиду индуктивность рассеяния, а не индуктивность обмотки, так как зазор сделать и можно ли феррит?
oleg1ma
Почитайте немного, меньше вопросов.По поводу Ls неизмерял за ненадобностью, по зазору сооб.№12737 здесь пилочку брал такую, но можно и сломать на трех гвоздях, вставить бумажечку и склеить.
Серёгин
Приветствую всех . Есть в наличии 8 колец 40Х25Х11 2000НМ. Подскажите ,уважаемые , можно из них сделать силовой трансформатор ? И какие намоточные данные на 35-40 кГц?
oleg1ma
Цитата(Серёгин @ 5.4.2012, 15:33) *
Приветствую всех . Есть в наличии 8 колец 40Х25Х11 2000НМ. Подскажите , можно из них сделать силовой трансформатор ? И какие намоточные данные на 35-40 кГц?
Уже поднимался вопрос неоднократно и силовой тр-тор понятие растяжимое, в БП или сварочный?Дырка маловата для сварочного тр-ра.
Серёгин
Всё понятно ...Вопрос снят !
ГонZа.Как успехи в инвертостроении ?
ГонZа
Вечер добрый.Всё ГУД!!Человек принёс магазинский трансформаторный аппарат,просит переделать на инвертор(оставляет только корпус и провода,остальное выкидывает).Буду переделывать,любой каприз за его деньги!У вас как дела,запустили аппарат?
Серёгин
ГонZа.Значит у вас работа есть icon_smile.gif ..У меня проблема появилась , не могу закончить свой второй аппарат ...У нас проблема стала транзисторы невозможно стало купить ! В ближайшем магазине (г.Ижевск )... уже месяц ! нет ничего подходящего !!!
ГонZа
Я купил сразу на запас 10штук(когда начал делать первый аппарат). Спросите у знатоков,где они выписывают транзисторы,может быть подскажут,здесь люди хорошие-помогут!
Серёгин
ГонZа. А вы сами откуда ? Где живёте ?
ГонZа
Кировская область.В городе Кирове.
Серёгин
ГонZа. Дэк вы совсем рядом живете ...
ГонZа
да,да соседи!
Серёгин
Дымодел
Извиняюсь за повторение, но где-то читал о такой конструкции силового трансформатора: три кольца (или три комплекта колец) на каждом намотана первичка и вторичка, при чём, сечение одинаковое и количество витков одинаковое. Потом соединяются - первички последовательно, вторички параллельно - и будет вам счастье.
Если лажа - извините за назойливость, но шибко интересно.
AS65
Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файлаДымодел
Сделать можно всё что угодно,можно намотать и как обычно.
В первом варианте моста Большакова применён транс почти на таких же
кольцах,посмотри думаю пригодится. ПВ большого не будет так как сечение вторички будет
маловато,у тебя же будет вторичка 6 витков а не 2 по3 половинного сечения.
Серёгин
AS65
Частоту придётся поднять только для этого количества витков в первичке или опятьже уменьшить её сечение
добавив витков.
Дымодел
AS65, спасибо.
Но имел в виду несколько другую конструкцию, а именно, транс разнесённый на три сердечника.
Сечение меди тоже будет в три раза больше, чем на одном кольце такого-же размера, и поверхность охлаждения тоже больше. В отличии от "бинокля" большая часть обмоток будет обдуваться. Аналогичную конструкцию видел в преобразователе 12/200в, но только на Ш сердечниках. Вот и стало интересно - есть смысл это мутить в косом?
AS65
Компоновать замучаешься.
Смысла нет,только ради спортивного интереса.
Dedan
+ для косаря еще и зазор нужен..
ГонZа
Вечер добрый.AS65,а вы не подскажете,можно ли вместо UC3825n(схема Большакова),применить SG3525 или TL494.Просто есть в наличии эти микросхемы,хотелось бы их куда-то применить.Прошу прощения у форума,что не в тему.С уважением Гонза.
oleg1ma
Сделай косой на 3525 от дантиста, хороший аппарат.
mono
Это спарка, или обычный, можно ссылку?
oleg1ma
Да спарка дантиста.
AS65
ГонZа
Это будет уже другой аппарат, посмотри на двухтактах там выкладывалось на 494той.
ГонZа
Большое спасибо всем за ответы!
UVM
Ребята, здесь косого (бармалея) обсуждают!
Sergei69
народ подскажите пожалуйста как определить цоколёвку P6KE200, кроме названия на нём ни х...на нет
кабельщик
Sergei69, если кроме названия на нем ничего (полоски) нет, то это симметричный супрессор. Мультиметром он не будет звониться в обоих направлениях.
oleg1ma
Если написано Р6КЕ200СА значит двуханодный и впаивать пофигу как, а если без СА должно быть колечко возле вывода катода и должен звонится как диод и паять его согласно схеме.
Sergei69
Огромное спасибо!!!
seljozha
Люди добрые помогите советом,если я намотаю 18-6 на 4 твс + зазор или нужно переститывать витки по квадрату.Или все же не критично.Катушка аналогично фото
sorry
На фото у Вас 6 сердечников, 18х6 у меня на 35-37 кГц, сечение учитывается фактическое а не по форме каркаса.
HEMELL
Намотать витков 30 первички проводом, диам. около 1мм., собрать обязательно с зазором около 0,3мм. (прозрачный скоч)
и на "калькулятор лысого".
seljozha
А хватит ли мне места ,чтобы получить на выходе 75-80 вольт 165 А и не тонковато первичка 1мм,думаю из 6 сердечников делать,а если зазоры оставить твсовские,будет не кретично?
oleg1ma
Делай как написано в файле. как раз твой вариант
Dimon4ig
Всем доброго времени суток!
Наконецто появилось свободное время, как советовали, попробовал блок питания на стабильность при разном напряжении, напряжение менял с помощью ЛАТР от 90В до 250В, во всем диапозоне на выходе блока питания 14,25В. В течении недели куплю практически все оставшиеся комплектующие, и в путь!
HEMELL
В этом файле сердечники ПК30х16, т.е. тяжело находимые. ПК20х16 найти гараздо легше, так что транс ему придёться делать на ПК20х16,
а значит кол-во витков придёться каректировать, ну и про литцендрат ему придёться забыть, он просто в такое окно не влезет, хотя нафик
он кому нужен, надо мотать обычным проводом. Дальше, думаю, что все сердечники нужно сложить в "ШАШКУ" и пробывать все обмотки
мотать на центральном керне, должно получиться.
oleg1ma
Ничего не нужно коректировать, а окно там такое, что и слона можно запихнуть, было-бы желание и руки из плечей.
HEMELL
Тем лучше для seljozha
mono
1мм для калька не надо, любой толщины провод подойдёт, обязательно проверь транс кальком Лысого. На выходе на 165А для сварки хватит 30 вольт и это уже будет больше 5-ти кВатт на входе, что не каждая розетка отдаст.
Вспомнил, сколько раз перематывал транс такой и потратил времени на настройку силы, никак не получалось получить нормальную индуктивность рассеяния, быстрее и с гораздо лучшим итогом сделать на двух совдеповских 20х28, там даже с каркасом без проблем всё влазит.
seljozha
Да вот хватит ли 30 вольт,мой знакомый утверждаеть что для плавки металла нужна мощьность ,а вот для зажига покрытия электрода нужно напряжение в пределах 75-80 вольт.Вот у меня возник вопрос,у меня остались от обычной трансформаторной сварки диоды мощные по моему вк200,для инвертора наверное нужны импульсные,стоит ли пробовать эти или уйдут в пробой?
oleg1ma
Диоды Ваши сюда непойдут, забудте, и если хотите иметь нормальный аппарат придерживайтесь схемы, а то ваши выдумки боком выйдут.Знакомый правильно говорит, в бармалее амплитуда выходного напряжения под 100вольт, а про 30вольт, это когда горит электрод.
seljozha
Так диоды дороже ключей,брал 50UD - 350 р провинция,а диоды дороже.Хотелочь бы нвродный проект.Мож паралель из совковых,доступных????
oleg1ma
А зачем брали с диодом тр-ры, потому и дорого, нужно было все выписать в нет магазине и не кормить барыг базарных.Как по мне лучше поставить пару ебуков или пять STTH6003, чем городить целый огород.
seljozha
Да я и не желею,по характеристике онн лучшет чем без диода,вопрос в том что просмотрел много схем,да силовая часть можно выполнить на чем угодно,да и транс мотакйте какой надо и что под рукой,тока надо считаь.Но это тоже не вопролс.Вопрос лиш стоит в том,как использовать то что у нас под ногами ибо можно платить вечно.А именно радио деталей широко применя в союзе.
Д713
о-о-о!
инверторостроение уже дотянулось своей костлявой рукой до полупьяных совхозных электриков..
a-nry
Привет Всем! Помогите разобраться с настройкой регулировки тока (Бармалей 165) мин. предел сейчас стоит на20А, мах. за пределами работы ключей)) по описаниям я понял ход действий, но с жизнью как то не клеется.
В пупкине довольно понятно но слишком сжато описан весь процесс, но на деле получается наоборот. Когда опорное напряжение на 2 ноге поднимаеш до предела (у меня оно 3,2В, задатчик в сторону R1.3к на мах) тогда и происходит огроничение. А по мах. току из того же понял, чтобы снизить порог мах. значения, нужно увеличить (R1.6Ом) тем самым подняв амплитуду на 3 ноге. Но еще не пробовал))
Хотел попросить помощи в настройке или ткнуть где можно узнать.
Заранее спасибо.
Basill
смотря по каким критериям и для какого применения
импровизировать в силовой электронике (как и в любой другой серьезной области знаний) без ущебра для здоровья и бюджета могут только опытные, если конечно важен результат, а не "процесс"
Тема об инверторе Barmaley'я. Для него из "союзных" радиодеталей можно применить: 1)феррит на трансы, железо на дроссель; 2) диоды от В25 на сетевой мост; 3) диоды КД9997А на выход; 4)электролиты К50-32 на силу; 5) плёночники К78-2 на снабберы и блокировку. Ну, и резисторы-коденсаторы по мелочи. Остального для данной схемы при союзе не выпускалось (для ширпотреба), как и не выпускались сварочные инверторы на IGBT.
