Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
DANTIST
Цитата(slavyann @ 22.12.2013, 17:30) *
где то проскакивало, что 3510 надежнее, чем 5010; а два моста наверна, чтобы уравнять кетайские амперии с нашими
Эт точно! Ну и площадь увеличивается, конечно.
Есть приличные мосты. Только вряд ли кто их будет покупать. Цена у них то же приличная. Вот и не возят коробейники из-за отсутствия спроса.
владимирон
подскажите в каких рамках должен быть кофициент заполнения шим у меня получилось 0,48
UVM
0,48 это максимально допустимое, лучше уменьшить для надёжности, я делал 0,43
владимирон
параметры кондера и резюка можно
Wasiliy61
Это ведь ещё зависит от частоты, какую частоту планируете.
Jorg63
для частоты 33-34 кгц и заполнение 0,43-0,44 номинылы элементов в частотке R-3kom,C-8.2 нан
владимирон
частоту планирую 36кгц шим 2845
Wasiliy61
8200 можно оставить, только резистор нужно убавить до 2,4 -2,7к
владимирон
все заполнение сделал 0,43 частота 36 кгц и последний вопрос все таки куда цеплять дежурку на блок литов или сразу на вход
Wasiliy61
Ну и что у тебя получилось, какая ёмкость и резистор. Дежурку цеплял и от 220в, и от литов, правда сейчас что-то задумался, так как от литов реле отпускает только через 30 сек, а если на последних секундах додут электричество, что-то я боюсь за мост, реле по идее должно сработать когда литы заряженны процентов на 80, или около этого, а через 30 сек в них остаётся 25 процентов, разрядный резистор на литах 91к.
владимирон
емкость 8200пф а резистор подстроечный стоит весь интерес проверить как себя поведет на морозе шим сейчас поставил кондер к71-7 и контролер 2845 но на улице 0 градусов стало буду ждать морозов
Вопрос ко всем сваркостроителям бармалеев кто при какой максимально отрицательной температуре варил .
UVM
Кондёр дежурки через диод на электролиты силы.
В результате дежурка будет отключаться после разрядки электролитов что убеорежёт ключи от всякого разного.
AS65
А чего их ждать сунь управу в морозилку потом включи и проверь.
Самое главное в мороз что бы в аппарате необразовался конденсат,
невноси в тёплое помещение с мороза и усё будет нормально.
Serega30
Всем здарова. Народ, посоветуйте как и чем аккуратно согнуть металический корпус для сварочника в домашних условиях?
SANDER57
Если нет листогиба,тогда мет.уголок,киянка и,самое главное,терпение и звукоизоляция(соседи)
mono
Без настольного гибочного станка не обойтись и то если металл тонкий, но вроде не в этой теме?
slavyann
не скажите, я согнул корпус при помощи куска швеллера и двух квадратных прутков, металл был 1.5 мм
Павел(Sp)
Нажмите для просмотра прикрепленного файлаДобрый всем,кому день кому вечер.
Чегото никак не возьму в толк гуд это или не очень....
Набор из 6 строчников импортных.
Площадь 1080мм2
25витков дают индуктивность 5180мкГн
по мю-калькулятору мю получается 1093.
ошибка +- пол-вареника но думаю что не очень большая.
L-мерялка самодельная на основе осцила,но проверял с разными стандатрными дросселями,ошибка между 3-5%.
Растолкуйте а то не дойду никак сам.
По параметрам материал близок к N93 или это я делек от истинны..
oleg1ma
Если втягиваешся в изготовление сварочников и т.д. то сделай по свободе, простенький листогиб.Не помню, кто и где скидывал описание листогиба, но проще некуда, я себе сварганил и теперь гну и загинаю, как нужно icon_biggrin.gif Вот такой вышел у меня, длину изгиба выбрал 95см, хватает для всех ящиков, фоткал летом, позже я его покрасил.
VladimirS
На просторах тырнета нашел вот такой вариант листогиба в квартире для мелочи из тонкого металла
http://tool-land.ru/ruchnoy-listogib.php
Serega30
Цитата(Wasiliy61 @ 26.12.2013, 14:22) *
Всем, добрый вечер.Вот такая марка конденсаторов, нормальные- как частото-задающие, как они держат частоту.Нажмите для просмотра прикрепленного файла Спасибо.
Такие и ставил... Обьясните, п-та, по каким критериям эти кондеры отличаются друг от друга?
voldemar_52
Красивый ровный загиб листового метала на коленках можно выполнить при помощи 2-х ровных уголков просверленных по краям. Установите размеренный лист разметкой на внутренний угол и стяните болтами до упора. Наружным углом поставите на наковаленку и легким ударом молотка по центру завершите дело.
Wasiliy61
Уважаемые друзья и коллеги, Поздравляю ВАС с Наступающим Новым 2014 годом, желаю СЧАСТЬЯ, ЗДОРОВЬЯ, ТВОРЧЕСКИХ УСПЕХОВ, и ДОЛГИХ ЛЕТ ЖИЗНИ. С Уважением ВАСИЛИЙ.
slavyann
вот корпус, гнутый без всякого станка
всех с Новым Годом понимаешь !!!
владимирон
уважаемые сваркостроители поздравляю с 2014 годом желаю в новом году творческих успехов и чтоб БАХА МЫ СЛУШАЛИ ТОЛЬКО НА ДИСКАХ
truevoxdei
Парни, С Новым Годом!!! И шоб всё плавилось и горело только на радость и во благо!!
Ной
С наступающим.Здоровья,остальное приложится.
RUS5610
Парни с наступающим всех!!!! Крепкого здоровья и счастья!!! Что бы дядюшка Бах не заходил в гости icon_smile.gif !!!
TRIDDD
С наступающим!!! Всем крепкого здоровья,семейного благополучия,всего самого наилучшего!!! С Уважением-Василий!
sergey777.68
truevoxdei
Цитата(gyrator @ 1.1.2014, 1:40) *
Всех болезных сварковаянием с наступающим Новым годом!
...И что бы обои в новом наступающем-наступившем стали реальными устройствами!
oleg1ma
Всех с Праздником
Jorg63
VOVA 555
Всех любителей сварковаятелей поздравляю с наступающим новым годом .Желаю вам всего самого наилучшего . Чтобы ваши поделки радовали вас и всемирно известный композитор обходил вас стороной .
Nikolay1
Дед мороз к вам идёт
Всех с Праздником
KT117
icon_smile.gif Да пребудет с вами Светлая сторона Силы и да будут целы ваши транзисторы в Новом 2014 году!
Navstar
С новым годом!
Вопрос по теме - каким проводом мотаете силовой у дешевого сверкальника? когда мотаю 2,24 помещается всего лишь 29 витковicon_sad.gif
slavyann
я мотаю везде проводом d 2 мм
Павел(Sp)
С наступившим всех.
Присоединяюсь ко всем пожеланиям и HEжелаю всем взрывов ,бахов,пожаров и тотальной разрухи в этом наступившем году.
Serega30
ВСЕХ С НАСТУПИВШЕМ 2014 ГОДОМ! Больше удачных проектов и меньше сожженых деталей!
Wasiliy61
Вот, сляпал управу. Пока не впаял резисторы 4,7ома- проблемма, придётся в платах поискать. Частоту сделал 50кгц, Кзап 0,43.Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла[attachment=3
0262:SAM_1370.JPG]Нажмите для просмотра прикрепленного файла
Нажмите для просмотра прикрепленного файла на печках.
Serega30
Wasiliy61, интересное крепление Тт... Можно по-подробнее?
Павел(Sp)
Сегодня выдался выходной.. с трудом нашел паяльник и вот наваял такого: осциллограмка с 1ом резистор в цепи обмотки,с нижниго ключа, 3я на самой обмотке,правда может трошки косая потому что через самодельный делитель на 125,силовое через лампу100вт ,на мост выходит 200в,падение на лампе 35в,транс 6 комплектов строчников 21виток тонкого монтажного провода.Транс вроде как не входит в насыщение,Потребляемый ток некак померять ,надо было курочить много,замерю как ключи менять буду на мощные,щас поставил какието на 40А.Напругу подавал через симисторный регулятор,пусть со мной не согласятся все кто хочет,но девайс фунциклирует без Б.
Wasiliy61
Да попалась какая-то пропка от пузырька, я её обрезал и приспособил. Может ты не об этом, Тт расположен на плате так , потому-что управа устанавливается вертикально на силовой части, там под Тт есть отверстие под один провод первички. Это тот проект, что я не давно выставлял. Я делал аппарат по подобому конструктиву, правда я те печатки по запарке удалил, но этот конструктив я сделал подобно тому,а управа эта не моя, а однако Димона, я её просто изменил под себя.
Wasiliy61
Нажмите для просмотра прикрепленного файла Уважаемые, кто знает-что это за тип конденсаторов, проводил эксперементы, ну просто изумительно держат ёмкость- при иэменении температуры, я имел ввиду ТКЕ.
oleg1ma
Serega30
Возвращаясь к техническим вопросам, хочу спросить: если у меня провод (идущий к задатчику тока) будет около 15-20 см это допустимо(учитывая то, что провод будет экранированым)?
Павел(Sp)
не думаю что смертельно, не уверен, но мне кажется Олег говорил что до 15см витой парой можно пускать, если 2х жилка экранированная то тем более, только экран с одной только стороны заземлять,чтоб не было разницы потенциалов земли и екран не выступал в роли первички.
Хотя может я и не правильно понимаю суть сего процесса..
and_w
Делал около 25 см длиной, обычным МГТФ, только свил его... Все нормально...
KSV
Прошу совета, хочу поставить на один радиатор и транзисторы и ключи, какие прокладки применить, как то ставил с БП АТХ, закончилось плачевно. Есть разбомбленый сварочник и хочу в него собрать свой очередной, компановку оставить как в оригинале на одном радиаторе. Стоит ли связыватся?
